1. Welcome to Jetboaters.net!
O2 Sensors - Service Bulletin
Discussion in 'Rotax Engine Topics' started by Rick215HO, Jun 12, 2018.
  1. Rick215HO
    Rick215HO Jet Boat Addict
    104
    Houston, TX
    Ratings:
    +145 / 2
    Boat Make:
    Year:
    Boat Model:
    HO Impulse
    Boat Length:
    I got a friendly call from MarineMax last week asking me to bring the boat over. Apparently BRP or Scarab has a service bulletin out to correct an issue with the cat. converters that was damaging the secondary O2 sensors. Obviously the service scheduler was not aware of what exactly they are doing... Anyone knows what is included in the service bulletin? Sounds like they found the O2 sensor issue...
    Anyway, sounds like good news...
    • Optimistic Optimistic x 1
  2. Dutchess77
    Dutchess77 Member
    15
    Sudbury, Ontario
    Ratings:
    +7 / 2
    Boat Make:
    Year:
    Boat Model:
    HO Impulse
    Boat Length:
    I'm not 100% sure but ours blew the O2 sensors & when we brought it in, they said there's a recall for that very item...they are all changed now.
  3. Terrance
    Terrance Well-Known Member
    30
    Porters Lake Nova Scotia Canada
    Ratings:
    +7 / 0
    Boat Make:
    Glastron
    Year:
    Boat Model:
    GT
    Boat Length:
    Hi Rick. Did you ever get a straight answer from your dealer on the service campaigns towards the o2 sensor problem? Thanks.
  4. mferrari
    mferrari Well-Known Member
    Delaware
    Ratings:
    +5 / 0
    Boat Make:
    Year:
    Boat Model:
    Impulse
    Boat Length:
    No recall that I am aware of but there is an o-ring that should be replaced to help with sensors damaged by water.
  5. Terrance
    30
    Ratings:
    +7 / 0
    Boat Make:
    Glastron
    Year:
    Boat Model:
    GT
    Boat Length:
    Thanks for the reply. I am running a 150hp BRP motor in a GT185 Glastron Jet Boat. After 150 hour running, and three o2 sensors later, I’m glad to hear that there might be a service bulletin and easy remedy. If you have any connection with the local dealership and can get a copy or duplication towards this service bulletin, and send it my way, that would be outstanding. I would let my local dealership tech know about this issue and perhaps other BRP powered boat owners will benefit from it.....just an idea. Thanks again for your information towards this sir!.
  6. Rick215HO
    104
    Houston, TX
    Ratings:
    +145 / 2
    Boat Make:
    Year:
    Boat Model:
    HO Impulse
    Boat Length:
    sorry I have not taken the boat in yet- perhaps this week. I let you know what I find out.
  7. Scarabtech
    Scarabtech Well-Known Member
    54
    Michigan
    Ratings:
    +30 / 1
    Year:
    Boat Model:
    Boat Length:
    The bulletin is due to the catalyst not being properly torqued at the factory. This can potentially cause water leaks internally that can damage the o2 sensors. There is a bulletin to retorque the bolts on the cat. There is also a bulletin that they are extending the warranty coverage on o2 sensors from 3 yrs to 10 yrs on early model engines.
    • Like Like x 1
  8. Rick215HO
    104
    Houston, TX
    Ratings:
    +145 / 2
    Boat Make:
    Year:
    Boat Model:
    HO Impulse
    Boat Length:
    Dealer fixed and its done. They changed the O2 sensors and apparently replaced a gasket on the cat. converters.
    • Like Like x 1
  9. Terrance
    30
    Ratings:
    +7 / 0
    Boat Make:
    Glastron
    Year:
    Boat Model:
    GT
    Boat Length:
    Hey Rick...glad your all fixed. Did you have a chance to get a copy of that service bulletin and 02 sensor warranty extension? I would love to have that in hand when I go back to the dealer. I had two O2 sensors replaced so far.
    Thanks
Share This Page
