Object in oil resouvior
Mondz3
Jet Ski
While I was changing my oil on one of my two 2017 VR deluxe a small hard plastic nipple came off inside the resiovor. I am unable to see it nor get it out. Will this cause me serious damage if I fill it back up with oil and try to start it up? Not sure what to do and beginning of summer all the shops are booked up for awhile.. Has anything like this happened to anybody else. Sounds like a stupid question just a lil bummed about my situation
WREKS
Port Saint Lucie, Florida
Is that Yamaha product?
Mondz3
Jet Ski
Yes yamaha
WREKS
1800 or 1050?
Mondz3
Jet Ski
WREKS
Is the dipstick in the oil cooler or in the engine block?
WREKS
Mondz3
Jet Ski
Really appreciate you taking the time to comment and trying to help btw
WREKS
With the dipstick in oil cooler, removing a foreign object is easy. With your motor, I think there could be damage if object is not removed. Both of those members are very familiar with jet skis.
Mondz3
Jet Ski
Yea I can see the object right near the dip stick so im assuming its further down? What will I have to remove in order to get to the lower section of tank?
Mondz3
Jet Ski
Yea I CANT see the object right near the dip stick so im assuming its further down? What will I have to remove in order to get to the lower section of tank?
Mondz3
Jet Ski
Hey one other question , I changed the oil on the other jet ski, and the check engine light is on? Is there a way to reset the light?
WREKS
Can you reach it with a long needle nose pliers?
Mondz3
Jet Ski
Unfortunately not, hole is so small pliers won't open and the hardest part is your fishing blind because not a big opening or angle to see while something is in there
WREKS
Can you modify a shop vac nozzle with a small diameter tip?
Mondz3
Jet Ski
Becuase the tank goes in a hole and down a curved tunnel it feels like seems unlikely I would need a bigger suction then the hole permits, but I like that idea
swatski
North Caldwell, NJ
This looks like a TR-1 oil change question. I believe @drewkaree has a Ph.D. degree in the field of TR-1 oil-ology, he might figure this out, it's a puzzler!
WREKS
If the oil tube goes down near the bottom of the pan, you may be below and moving parts, but I would still try to remove it. Maybe the pan has a plug in bottom where it can be flushed out.
Mondz3
Jet Ski
Thanks for the reference
