Marcio Fazzio Martins
2004 AR230
With the engine out, I was able to find where the oil leak is located.
It is leaking from the whole on the Flywheel Cover where the cables from Strator exits.
The idea is to take the cover out and use some high temperature gasket maker to seal around the rubber.
I have never opened this cover, but looking at the service manual and parts book it seems that this rubber seal that is part of the wires assembly is held in place by a metal parts with 2 screws.
If anyone had experienced this leak and/or fixed, leave a comment.
Thanks
Thanks
