RobT
Yes, I still have oil injection and it seems dry where the oil filters are located.Hard to say with that single pic and view. You still have oil injection, right? I would check that each oil line is attached to the underside of the arrestor. I would also check all connections from the oil tank to the oil filters and pumps. It seems less likely that it is the latter since the oil is collecting in the back compartment of the boat which is not where the tank and filter would leak to.
On the engines I have sprayed silicon lubricant nothing else. I'm wondering if the blue oil like complete my out of the zerk where you put intermediate housing grease!!! Don't know. But the other residue is dark color like oil mixed with water sort off.Could it be residue from any oil that you might have sprayed down the engines with?
The leak in the second chanel is same as you described above. I'll check for bad hoses or clamps. Thank youCheck for bad hoses or clamps on your exhaust , the exhaust has oil in it and when a hoses leak or the water box wears a hole in it etc the exhaust and water with oil will get in the hull. The oil will look dark or black from the carbon during the combustion process, also the engine may feel a bit sluggish since it is pulling in exhaust gases from the leak. Also those were NOTORIOUS for the oil injection lines falling off and destroying a cylinder, so be very sure your oil lines are ALL connected as they should be.
Memory from the OLD site where the hell is the steve price tips section when you need it.
I've took the boat out around 5 times this year. I own this boat for about over an year and I've never greased the bearings so it could be liquified marine grease. I'll put some grease this weekend and will see. Thank youHow long has the boat been sitting? The blue looks like it could be marine grease from the seal or coupler. But it would have to have been sitting a while for it to liquefy like that.
Only other oil would be the pre-mix. Does it match the color of oil you're using?
I use yamalube which has like dark purple colorHow long has the boat been sitting? The blue looks like it could be marine grease from the seal or coupler. But it would have to have been sitting a while for it to liquefy like that.
Hey, Just wondering if you every found the source of the leak? I have some oil leaking in the rear channel as well; looks like yamalube. Can't find the source. Any help would be greatly appreciated guysI use yamalube which has like dark purple color
I really appreciate the quick reply . Thanks so much. It looks like the last owner actually had the clamps replaced on the lines from the oil pump. Everything looks secure. I traced the lines all the way from the oil tank to the filters, to the pump and up to in injectors; doesnt seem to be any leaks along the lines. Its strange.Welcome aboard @bluejay1977. I'm assuming that you came here to find help in locating your leak. I don't have any Yamaha 2 stroke experience. But in my sea Doo, I had similar puddles of oil. I ended up replacing all of my oil lines (from tank to oil injector pumps and from pumps to carb). From what I've read, Yamaha oil lines were suceptable to shrinkage and would pull off and burn up cylinders. So that's where I'd start looking for leaks first. But I'm sure guys with more accurate Yamaha 2 stroke advice will chime in shortly.
Hey RobT, thanks for your reply. Im gonna take the carb cover off to see if I can trace the leak; I'll let you know if I find it. Also, At full throttle, Im now finding that one engine runs at 7000 rpm and the other at 6500; have you ever run into this sort of thing? Im hoping its just a high speed idle screw adjustment.Sorry I wasn't able to find the source of the leak. The blue leak looks like liquefied Yamaha blue marine grease and the dark is yamalube. It is coming out from under the engine but I can't tell from where. I checked the hoses and everything look ok...
