Tommy Lee
- Scarab
- Other
So... I know that this is somewhat of a tackled subject, both here and on other web sites dealing with both automotive and marine engines. I am just wondering however, if in my case I am dealing with simply a failing valve cover gasket, or worst case a possible leaky piston chamber (I freaking hope not), or other issue that could cause this.
When I changed the oil and filter last week, as well as spark plugs before my first launch of 2021, I noticed the oil was about 1/3rd to half less than it should be, and that's when I noticed the oil on the spark plug threads. The engine/boat only has 111 hours on it. The engine did not misfire at all when driving it for the couple hours we took it out last Saturday.
My question at this point is, considering the number of hours, the amount of oil missing etc., is this probably more serious than a valve cover gasket issue? Should I try tightening the valve cover (check by tightening to torque spec and see if the bolts are not torqued all the way) before ordering a new gasket? If it is the valve cover I would imagine there'd be oil pouring down the sides of the engine or pulling somewhere other than inside the spark plug wells?
Thoughts?
Thoughts?
