  • Annoucing the SURFtember Surf Board Group Buy for JetBoaters.net members only Hosted by Transom Watersports now through September 30!
    BEST pricing of the season on the most popular wakesurf boards for jetboaters!
    - All in stock 2019 wakesurf boards on major discount, including the Popular Slingshot Coaster, Quantities are limited, only 15 buyer minimum
    You can dismiss this notice by clicking the "X" in the upper right corner >>>>>>
  • Announcing the 2019 Jetboat Pilot SEADEK Group Buy for JetBoaters.net members only! This is your best time to buy Seadek from JetboatPilot - you won't get a better price - the discount has now reached the maximum 30% already!
    So if you are tired of stepping on really hot snaps/carpet, or tired of that musty carpet smell - Seadeck is the best alternative out there! Get in on this now, or pay more later!
Oil pressure switch?
Bill425
Chaparral
VRX
I got a 2016 243 chaparral with twin 250 hp supercharged brp rotax engines. Model of engines are 1503. I posted previously regarding an engine oil leak but managed to locate it and it ended up being the very center of the oil pressure switch. My problem now is locating the correct replacement along with the part number and an on line parts supplier. I talked to 2 dealers so far and both weren’t to knowledgeable regarding the part. Can anyone provide some information on the part or can an after market part be substituted? Hope someone can help! Thanks!
Mr.Happy
Chaparral
VRX
OIL PRESSURE SWITCH 420856533
(i have the same problem last year by my vortex 223 with 250HP)
Bill425
Chaparral
VRX
2 weeks ago I ordered the pressure switch and am waiting for it to come in. Looks like I may be able to remove the old one with a deep dish socket without removing the throttle body by going straight in under it using extensions. Did you replace yours yourself? If so, how did you do it?
Mr.Happy
Chaparral
VRX
i have changed this only with a 24mm nut (long version) in under 10 minutes. i dont remove other parts by this job. very easy :)
101362
Bill425
Chaparral
VRX
Glad to hear that! Thanks!
Bill425
Chaparral
VRX
I have been waiting for the oil pressure switch which I ordered from the dealership back on July 19th and it still hasn’t come in. Do you know what the part number is that you used and can you use a compatible part from seafood?
Mr.Happy
Chaparral
VRX
Only the number what you see above.... i have no another number.
Bill425
Chaparral
VRX
Put the new switch in and reset computer on medallion screen but P0024 still comes up as oil pressure switch and can’t be cleared. Engine still runs in limp mode. Have a seafood tech coming with buds diagnostic to see what the problem is. Will keep you posted.
