caborouse07
- Key West Fl
I have an 2005 AR230. I had an issue this weekend with battery switch being corroded and had to replace. After completing the change the engines start right back up. However one of the engines had a low oil pressure light come on. I turned it off and waited like 10 min. to restart. I check oil level and it was fine. After that the light never came back on, I used the boat for the rest of the day with no issues. Is this something that is common after disconnecting the battery? Anything to be concerned about?
