Oil valve
Ralph195
North Miami Florida
195 G
I was tighting a clamp and an electrical plug was in the way pulled it out work on the clamp put the plug back in. It was a little bit crooked so I pulled it out but the whole part came apart and open. There was valves and a spring next to the valve and someone told me it was a valve that if the boat flipped over the oil will be prevented from seeping out. Does anyone know the part number on a 150hp installed in a 2016 Scarab 195?
tdonoughue
The Woodlands, TX 77381
Might try someplace like Rotax Parts :: GoRotax.com where they have parts diagrams to try to find it. Then it should tell you what it is called and let you get another one.
