2kwik4u
- Georgetown, IN
Having some HVAC issues at the house and need some help.
About 6 times now I've had to "reset" my air conditioner. Basically I realize it hasn't run in awhile or seems absurdly warm in the house and I go check the temp. Set to 71, and usually it's around 75-77 when I notice. I turn the thermostat to off. Then go and turn off the breakers on the unit. Then turn off the breakers in the house panel. Wait 5 min. Turn on the house breakers, turn on the unit breakers, and turn the thermostat back to cool. Wait about 2 min and it kicks back on. Once running again it will go for 3-5 days before it does it again.
Things I've checked.
I've called the company that installed it (left a sticker on the unit), but they aren't calling back. I don't mind paying someone to come look at it and check it out.
Hoping someone here has some insight. Any thoughts?
- Filter is clean and fresh.
- Vents in basement are mostly closed
- Vents upstairs are mostly open
- Condensate overflow switch is operational, and drain is clear
- Return air ducts have been cleaned (as far as my shop vac and lint lizard can reach anyway)
- Outdoor portion (condenser?) is clean and clear of debris. Insulation around the line looks a little chewed up, but not terrible. Electric disconnect out there is clean and working as intended.
