peehole name?
Skeeter456
NY
lol sooo what is the sx190's peehole name? Yesterday while washing my boat I snapped off the screw in gray elbow that comes out of it. Looking to buy another one but dont know the real name or where to look. Thanks
Skeeter456
NY
veedubtek
Punta Gorda, FL
Scout
Someone on here found some aluminum ones that fit and looked beautiful. I just can't seem to remember who at the moment...
Skeeter456
NY
Its a piss poor made part. I was not even scrubbing hard and it went flying.
haknslash
Lake Martin, AL
Moomba
Skeeter456
NY
Will those screw into my black nut already on the boat?
Edit: ahh i see its the whole setup! Thank you!!!! Now how about a better looking gas cap?
Ronnie
SF Bay Area
FYI I see now that Yamaha calls the assembly a “Pilot Water Outlet” but I recall Jet Boat Pilot referring to it as a cooling outlet which is more descriptive in my opinion but being on this sight and YJB I’m still more familiar with the terms pisser or pee hole, but if this is correct shouldnt the part or assembly be called a d ch or penis?
njmr2fan
Augusta GA
How about we group buy a bunch of them pisser- pee hole-cooling outlet thingies?
FLBulldogger
haknslash
Lake Martin, AL
Moomba
I think the bilge is 3/4" and the pissers 1/2". @Rick Owens replaced all of his including the bilge so perhaps he will chime in. Several members have swapped theirs out and posting info in pics buried in @SamCF 's SX192 mod thread
FLBulldogger
I REALLY like this upgrade however I just went out and unscrewed the Pee Hole and tried to pull the hose and connectors out and no give in the line. Screwed the outlet back on and said ok how does one do this? I looked in the stern starboard holding space and could not trace either line the bilge or pee hole....Request an assist from you guys on the "how-to" on this one. Thanks
haknslash
Lake Martin, AL
Moomba
The lines are the in the starboard storage. Have to stick your head way in there and look up and towards the rear/side.
FLBulldogger
Thanks @haknslash I knew I could count on you! :thumbsup: I will take a look in the morning and see what I can see...
haknslash
Lake Martin, AL
Moomba
Here you go. Went out and snagged some pics for you. I'm pointing in the direction of the hoses. Once you stick your head in there you will see them. The fittings have nuts on the inside/backside, not just on the outside of the hull, so that's why yours weren't budging when you removed the outer nuts. If you look close you can see the nuts ;). The red line is what goes to the flush port adapter in case you're wondering.
Seadeals
Greenville, South Carolina
Those are very cool. Now I have two more mods on the neverending list: peckers and a fancy sphincter (gas cap)! Both sound inappropriately appropriate given the bodily references. I like heap mods like this. You can fit them between the expensive mods to keep your mod “buzz” going.
FLBulldogger
Got them in this morning looks pretty cool. Install was relatively painless, except for using the dremel barrel sander to enlarge the pisser hole about a 1/16 of an inch....
