Plastic to fiberglass bond?
__ScottyDont
Leonardtown, MD
Trying to run some wires and bond some plastic channel pieces on the inside wall of the hull that you can put a wire tie threw.
Essentially looking to bond smooth plastic to fiberglass. I've tried 5200 and double sided tape. Both came apart after a few days.
Murf'n'surf
Naples Florida
Use the 2 part epoxy mix of your choice. Marine Tex has one there are many more out there that can be found at Home Creepo too.
