please help 2016 yamaha 242 LES
Johnlj1992
i am a fairly new boat owner and am having issues
the boat is only going to 8 mph then revs up horribly if i try to go any faster almost as if it has a governor on it
i called the dealer but they are 8 weeks out for service and am not wanting to wait that long if it could be something simple
please let me know if somebody has dealt with these issues
djetok
Edmond, ok
Are you getting rpms and no thrust? (Clenout plugs)
Johnlj1992
yes hitting 4000-4500 rpms the cleanout plug was left open while on lake for a couple of hours also..
djetok
Edmond, ok
If they are not seated properly you will get no thrust and a lot of rpms. It will cause little to no cooling to your motors. Make sure the cleanout plug is fully up and locked
When you inserted the plugs did that solve it or not. Couple easy things like spark plugs. You might check your oil levels, put a level on the motor if on a trailer and check. I always check mine on the water after I change the oil. If your oil is over filled you may want to look at the air filters. There may be oil in the filter if it's over filled.
Johnlj1992
do you know if it would be an immediate fix or would i have to ride around for a bit?
the drive control on the connext screen was also giving me issues but that could be of no thrust i suppose
djetok
Edmond, ok
I dont have a connext , so no help here. @swatski @Mainah would be my first persons I would ask
Johnlj1992
sorry i said cleanout plug it was actually the drain plug that was left open
djetok
Edmond, ok
Immediate fix for the thrust? Yes that should be , if your talking about cleanouts. If the drain plug was out . How much water got into the engine compartment? Like how far up the engine. Did the ecu get wet?
djetok
Edmond, ok
If you have rpms and no thrust , it is probably cleanouts not seated completely. If you dont have ezlocks on your plugs. I would get them asap.
djetok
Edmond, ok
If your stuck on the water or in urgent need you can put @ help without the space and people will be alerted.
Johnlj1992
no the boat goes up to 8 mph so we just idled it back to the lift but thanks
Johnlj1992
do you know where i could get those?
djetok
Edmond, ok
Bruce
Royal, AR
Three possibilities;
1. The clean out plugs are not installed.
2. Something is in the pumps, kill the engines, pull the clean out plugs and feel for anything in there.
3. The impellers or some other pump parts are severely damaged causing cavitation.
John McLaughlin
Ocean Pines Md
I assume that when you got back to the lift you placed your boat on it and let the water drain. Am I correct? If so once you put the drain plug back in did you restart the engines and take the boat back out and did it get back up to speed?.
As to the clean out plugs I have had it happen to me. In each case it was because I did not seat the clean out plug correctly, however I have never had both plugs blowout at the same time. I would recommend that when you put them you give the a good tug to ensure they are seated properly. [flag]
djetok
Edmond, ok
Lots of great suggestions @Johnlj1992 above this. @Bruce pretty much laid it out in one post.
Johnlj1992
yes as soon as we saw that we let it drain then went back out but nothing had changed
swatski
North Caldwell, NJ
@Johnlj1992 based on your signature your boat would still use the older cleanout plugs with the "dogs", not the newer screw-in type. As already suggested make sure those are sitting in completely, locked and not "crooked".
I doubt your impellers are that bad to explain your issues but if you stick a phone camera into the cleanout ports you can shoot some oics of those and post here, also take some through the intakes under the hull.
E-series boats can be finicky with low battery power, so make sure you check that - are the batteries fully charged? and all the connections tight? The Connext uses tachs for routing information, so make sure the connections on the Connext and tachs (behind the helm/dash) are not loose.
Check the map if there are any forum users nearby, people here are very helpful and may be able to meet you and give you a hand. You can list your (approximate) location in your signature, too, that may help.
captras
Lake Livingston, Texas
make sure you dont have anything wrapped around the impeller. You take out the plugs to check this. I have had something stuck and get almost identical to what you are saying....idle, but when you give it gas, RPMs increase with little or no thrust. If you are getting an abnormal vibration when you try to accelerate it is another indication that something might be stuck in or wrapped around the impeller(s)
