ZippyBoater
- Lake Gaston, VA
- SX
What am I missing? I can't figure it out.
Starboard engine starts and runs well. Checking fuses when it is light enough. Where are the fuel filters located? I didn't think they had filters. What fuel valve?Remove and re-install the safety lanyard.
Fuse in the CDI box?
Fuel valve open?
Fuel filter clogged?
With the lanyard out, the engines don't even crank. Mine crank, but the port is not firing up.I have had this issue twice. For me it was the lanyard switch twice.
The switch is open when the lanyard is clipped on, which means if your unplug the switch from the boat, the switch has been bypassed, and if this is your problem, the motor will start.
Best of luck
So, let me get this straight, my safety lanyard switch could be causing my problem with starting? When I look at the wiring diagram, the way that it is wired, when the lanyard is pulled, the electric circuit to the engine is completely broken, nothing will run, no spark for the plugs, no juice for the starter. How does that effect the engine not firing up? The starter is turning over the engine, but it is not firing up.The lanyard switch can be finicky and a affect only one engine. Glad it started!!! Keep an eye on it. I jiggled mine enough that it fixed itself, to fail 12 months later. I replaced it with one I made and so far so good, but it's been only a few weeks.
It's got to be.WTF???? Is it a loose wire somewhere?
My boat is a 2009. I confirmed through the wiring diagram and through pulling the lanyard and opening the clean out hatch that they open the electrical circuit to both motors. With the lanyard pulled and the clean out hatch open, no electric current flows to the starter or the coils. This is to prevent the impeller turning with your hand in the clean outs or if the operator is thrown overboard.On my boat only spark is prevented when the lanyard is pulled. It still cranks. I was wrong to think yours was identical. Maybe we can find a wiring diagram for your exact boat, and confirm what switches can kill spark. What year is your boat?
3/4 tankWhere is your fuel level? On my old boat, SR230, I ran low on gas and one of the engines cut out. I was able to idle another ten minutes on the other one before that one quit.
I am looking for it online. I am away from my boat and manuals.This is how the wiring works on mine (mine is a SX230)
#8 is the lanyard switch. We need to find and understand a similar wiring diagram that matches your boat to get a good picture of how it works.
I am stumped too. I was wondering if YDS could help? Maybe the engine is throwing a code or two when it happens?On the 230 there are 2 circuits to mess with the engine's ability to start. One is the Neutral switch, which is triggered by the neutral lever and the clean out hatch. This prevents cranking, but does not cause the engine to shut off. The other is the ignition kill, and kills spark, and shuts down a running engine, but does not prevent cranking. The rear hatch triggers both circuits on the SX230, and the lanyard only triggers the spark side. These MR-1s are so reliable it's generally something simple like the switches or lanyard or loose cable. Sorry I'm so stumped on your engine not cranking with the lanyard off. I wish mine did that.
Yes, that is correct. However, I am starting to doubt that and may have combined some of the trouble shooting steps.And this is just a re-confirmation to be on the same page. On your SX210 With the clean out hatch securely closed, and the lanyard pulled, if you try to start the motors, neither engine cranks/spins/ same as no power to starter? and with the lanyard on, while you are having this issue, One engine start fine and the other cranks/spins but does not start.
Is this correct?
