Port o potty wont empty via suction/pump out on 243vrx
MGrande305
Chaparral
VRX
I took my 243vrx to the pump out station at the marina the other day to have the port-o-potty emptied via the pump out port on the port bow. Well, the dock personnel hooked up the suction device and it didn't suck anything out of the port-o-potty even tho it's almost full ( which has only "liquid" in it btw). What's the issue? I looked to see if there is a valve that might be closed but didn't see one.
Cut2thechase
New Bedford, Ma
Chaparral
VRX
There is no valve on the back of the catch basin. I had to take everything out to clean it this spring. I'm not 100% sure on this but you have to have the valve closed from the toilet to the catch basin. There should be a diagram on the lid of the toilet that explains the steps on how to "prime?" the toilet basin also.
anmut
212S
Gross - not sure how you guys deal with that. "pee in the water, crap on the island... or better yet, go to the bathroom before we launch."
MGrande305
Chaparral
VRX
Ok cool thanks! I'll check that out. I think I had the valve open from the toilet to the catch basin as i assumed it would need air to for the vacuum to work.
Cut2thechase
New Bedford, Ma
Chaparral
VRX
If you don't have the instructions on the lid let me know. Probably won't get ours out until Monday at the earliest (lovely weather for the 4th in New England) but I can send you a photo of it. Good luck!
Ronnie
SF Bay Area
At least you guys get a built in head with a clean out port. Some Yamaha boats have a compartment for a head but not the head itself and no plumbing for a clean out port. If you can’t get the clean out port to work consider replacing the oem head with a self contained unit. Emptying it is easy, just pull the unit out, take the lower half to a toilet and drain it there. Such a head usually sells for $120 or die anyway. Good luck finding a quick and clean solution.
