I am about to begin some lighting upgrades (interior and exterior) and need some ideas! Please show off your improvements. What you did, tips, manufacturers...
Guys, if you all have any pictures of the installs to accompany your beautifully luminated boat pics that would be great! Suggestions on routing your wiring, mounting the lights, etc.....That would really help out a lot
@JerryG Here is some details about mine, I found it: https://jetboaters.net/threads/cockpit-led-lighting-in-sx190.8835/ @Danielmailin had some good tips that I followed for drilling some holes under/on the edges of cushions and running a silicone bead. as far as wire - I think I used 16AWG speaker wire, as I had a bunch of leftovers. Good soldering iron is a must, otherwise you will be miserable if use that route (with some type of heat shrink tubing), unless of course you use some type of connectors.
Just brace yourself for some serious fiberglass itch. Fortunately, it only takes about a week to resolve, hehe .
Stuff needed:
LEDs
wire
waterproof butt connectors
heat gun
drill/bits
wire stipper/snip
acetone
cotton balls
small zip ties
Male/female adapters (optional)
wire pull of some type
Skinny arms and long sleeves
At the LED locations inside the boat I had to drill a small hole to feed the wire through. I used acetone to clean the fiberglass at the locations where the strips would go to make sure there was good adhesion of the 3m tape on the strips. At the air intakes on the rear of the boat I was able to drill the hole from the inside of the engine compartment, but I installed the led from the outside without removing the seat backs. Small hands are needed though...hence my 10 year old helping me. I ended up attaching those LEDs to the seatbacks rather than on the fiberglass in the intakes because I wanted a glow versus being able to see the lights themselves. Time will tell if that was a smart choice. I think I'm going to go ahead and order one space package of LEDs in case they come loose. So far so good.
I you want I can take some photos of the lights themselves. I'm planning to take the top off tomorrow evening to work on my wake tower speaker/amp install.
In each location inside the boat, the lights are pushed up as far as possible under the freeboard cushions so you can't see them without looking from below. The interior ones in the bow and in the stern are above the hand grips. The one across from the helm lights up the JBP series plate my boat boat has.
This is a really easy project, but really cool if you are ever out at night.
Finally got a chance to get some pics of where/how I did the lights. There are a lot of pics so apologies in advance.
Bow lights, both the same.
Light at port bench.
You can see the drilled hole to the right. This next pic shows that by keeping them as tight as I could to the cushion you can's see them unless you get really low.
Over aft hand grips. I was able to get these really up into the space and they probably look the best (glow-wise) of the cabin lights.
These are where the wires come through from the swim platform. If you look you can see the lights on the seat back in the first one.
Love it. 1 question @JerryG , @swatski , is it a soft glow at night or is it a bright glow? In every picture I see LEDs seem to be crazy bright and I want a soft glow.
