Pump controller com error
jonbidwell
Big Bear Lake
I have a 2020 Yamaha AR242XE and today while I was filling ballasts, got this error, "Pump controller com error." I have tried things on these forums, such as unplugging connector, disconnecting batteries, and even trying to re calibrate ballast system. Nothing works. Has anyone out there figured out something new with this issue? Thanks in advance.
jonbidwell
Big Bear Lake
******Found Issues******
It was a blown fuse next to the solar panel fuse. Dealer didn’t know this.
jonbidwell
Big Bear Lake
It is in the battery compartment near the rear. There are 2 floating fuses next to each other just to the rear of the accessory fuse box. One is the radio fuse, and one is the ballast system fuse. The fuse blew when the launch ramp was decontaminating my boat. They didn’t turn the water on, so the system was sucking air the whole time. Don’t know why this caused the fuse to blow, but it did. I tested ballast system all day today, and no issues!
