Setec_Fl
update. Skip to my last post with the block diagram and equipment list.
I recently purchased a used Yamaha jet boat and the previous owner added a lot of stuff to the stereo system that I don’t think are needed.
There are 3 amps of various size. 1 for the subs. 1 for the deck speakers and tweeters in the tower and 1 for the 10” speakers in the tower.
there is also an electronic equalizer and a crossover. So 5 pieces of equipment all mounted to 1 board in the storage locker and the wiring is a nightmare. A ton of RCA plugs that aren’t sealed.
My issue is, there is a lot of noise in the speakers and occasional popping. I am trying to diagnose the issues, but I am thinking of taking everything out and starting over.
Are things like the equalizer and crossover really of any use on a boat? Any suggestions on how to better deal with the RCA plugs?
maybe, rather than 3 separate amps, I get 1 multi-channel amp that can drive all speakers?
I can post a picture of this rats nest if it helps.
oh, and the speaker wires are just ran haphazardly. Not even routed through the wire mounts. So I’m sure some of the noise is from that.
