Questions for Ron@Scarab (Or anyone that knows the answers)
WaltB
HO Impulse
Hi Ron,
I see your knowledgable posts in this forum and wanted to ask you some questions. Just for an introduction, do you work for Scarab or are you a Scarab dealer?
Thanks,
Walt
2016 215 HO Impulse Wake:
1. I have two towing attachment points. The one at the top of the the tower and the one at the back of the boat. What are my limitations on the tower attachment? Only tow wake surfers with this one?
2. On the back of the Viper II circuit board there is a Wi-Fi antenna. (Labeled Wi-Fi) What is this for? I connect my phone to the system via BlueTooth so I’m curious what this is for.
3. Where does the factory put a second battery on the 215 HOI wake boat? I am interested in installing a 2nd battery but am not sure what location to use. (The wake ballast bags take up the compartments on the sides)
4. The new towers on the 215 HOI, 2017> use metal poles angled to the front for additional tower stability under speed. My 2016 has straps. Can my boat be retrofitted with the poles or were there changes to the tower to allow the installation of poles in the 2017> models?
5. The wet storage area at the back of the boat does not drain statically or while underway, what is the fix to this problem? I have confirmed there is not obstruction by sticking the garden hose in the hole and under pressure, pushing water through the hole and out the drain under the boat.
Ron@Scarab
Fort Myers, Florida
HO Impulse
I am both my friend.
(I believe I answered these questions somewhere for somebody recently:)
Tower top or lower attachment: Rule is one line for ONE person doing the activity, period. What you do later, is up to you, but don't blame Scarab if you snap things, lol!
HOI Tower Extensions: My recommendation is to have a local canvas shop add them for you. I know this isn't the answer you probably want to hear, but we don't have anything for that.
Wi-fi,..has nothing to do with any applications we have offered etc. ( I will check some of our boats radio manuals for you since I haven't seen anything on this yet.)
If the drains aren't draining have your dealer look for kinks in the hoses, or check the valve itself. That is the only issue we ever come across.
In 2016, there wasn't an option for a Dual Battery setup. You will need to find a place suitable depending on your needs and add another switch for dual batteries. Your dealer can do this for you.
In 2017, we don't offer dual batteries either. I would add it in the rear seat compartment, but you have ballasts so that eliminates that idea. If you didn't have those, that would be a perfect spot.
I know this doesn't sound like helped a lot, but what you are seeking remains to the minds of the aftermarket.
WaltB
HO Impulse
Ron,
That was a big help! I appreciate you being on this forum and assisting us with issues as well as answers to our questions.
Walt
ScarabMike
Green Cove Springs, FL
The top tow point is only to be used for skiing or knee boarding. If your going to be tubing, or towing a watercraft, you need to use the lower.
Wifi is for system firmware updates, and future apps/add ons
I have written a detailed how-to for adding a second battery. Head over to the Scarab repository and you will find it. Eventough you dont have a 195, the process is similar.
https://jetboaters.net/threads/scarab-add-a-battery-modification.3135/#post-85751
Your wet storage should drain to the bilge. Because of this, there is no way to have it weep while under way like the Skis do.
WaltB
HO Impulse
Hi Mike,
"I have written a detailed how-to for adding a second battery."
You have done an excellent job detailing how to do the install. I was looking for where the factory would locate the second batter in 215 HO Impulse Wake. The ballast bags occupy the all the possible location aft of the helm. Ron answered that there was no factory option for a second battery so I will have to find a place amidship.
It does not do so on the 215. It drains overboard underneath the rear platform and out. Unfortunately, mine only drains when I put air or water pressure from the entry point to force it out. As Ron said there is probably a kink in the hose. I'll have to pursue that angle.
Thanks for your input.
Walt
Need A Vacation
Mid-Mi
215 ID
@WaltB,
Did you ever find a good location for a second battery?
Any pics if so?
TY!
WaltB
HO Impulse
I could not find a place I liked that would either not interfere with the ballast bags or be all the way up at the helm so I have not installed a second battery.
Walt
Need A Vacation
Mid-Mi
215 ID
I could not find a place I liked that would either not interfere with the ballast bags or be all the way up at the helm so I have not installed a second battery. Walt
TY for the reply!!!
We are very close to going with a 215, but we wont have any ballast bags. So I am considering under the rear side starboard seat.
Though I haven’t looked that close yet. Does there happen to be enough room in the motor area, on the starboard side (like the factory battery is on the port side) without any ballast bags?
TY!
WaltB
HO Impulse
No room in the engine compartment of the 215.
Under either rear side bench seat would work perfect,,,, as long as you don’t have the ballast bags.
Walt
Scarabpaul
Bradford, Ontario, Canada
I installed my second battery on the starboard side below the rear bench seat close to the engine bay. Fits perfect and takes up minimal space.
Need A Vacation
Mid-Mi
215 ID
