- Royal, AR
- SX
I changed the worn out (I assume factory) axial tires on my SX230 trailer. The new Towmaster brand radial tires were just under $400 installed for the four. I had been concerned that I could not roll the SX230 around in the garage with the axial tires. I was pleasantly surprised that I can roll it easily with the new radial (Towmaster) tires. Going from not being able to push the boat around on a smooth flat slab to pushing it almost as easy as I did the LX210 is a huge difference.
I also experienced an increase of fuel mileage. I believe it added at least 1 MPG.
