Billtex2000
- Lake Wallenpaupack, PA
- SX
I'm having a random starting issue on a 2006 SX210. It started on the port engine and would happen intermittently. I'd turn the key to "run", and when I'd attempt to start...nothing. Not a sound...no click, no growl, no crank. I'd go back to "run" and try again and it would fire right up. Sometimes it would take 2-3 times. I was leaning toward a bad switch, but now the starboard engine is doing the same thing! Totally random, back and forth. Sometimes they both fire right up, but only one seems to be "dead" at a time. They've both eventually fire up after a few times, port or starboard, but I'm worried that my luck is running out. Battery is brand new (first thing I did was get a fresh one.) I've checked the cleanout and lanyard kill switches and they seem fine. The ignition switches are tight in the dash and the connections are good. I'm stumped. Any help is appreciated. Thanks!
