Reinforcing hollow seat base with closed cell foam (Yamaha SX230, AR230)
Bruce
Royal, AR
The bolster attachments had cracked the base of my seat making the bolster difficult to open and close.
I had speculated about building a metal structure to reinforce the plastic. After further consideration I decided to try reinforcing the plastic with closed cell foam. I have forgotten exactly what I used but suspect it was Loctite Tite Foam. The seat base and bolster has held up to two summers of use including two 10+ day Bimini trips since the foaming.
I believe this picture will illustrate the process. I drilled holes of sufficient diameter to insert the foam nozzle into the seat base and sprayed a small amount of foam into the base allowing it to expand to fill the void but being careful not to spray too much at any point. I then drilled additional holes to fill remaining voids. At the end the once hollow seat base was a much stronger solid structure.
Finally I drilled new holes trough the bolster mount.
buckbuck
Texas
I had the same thing happen to me a couple years ago. I tried foam but it only lasted a year. I ended up pumping it full of construction adhesive and reinforced with some aluminum angle. I wish I had thought of your solution.
Bruce
Royal, AR
I believe the close cell foam that I used would fall somewhere between typical foam and the construction adhesive that you used.
