Removing swim deck radio controller
DRAT
Sachse, TX
2015 AR240, can anyone tell me how to remove the swim deck radio controller panel and what I will find once removed? Mine is non-operational, had to disconnect it to stop "stereo comm error" warning and now I'd like to replace it. I don't want to destroy it while removing it if I don't have anything to put in its place but I don't know the size and shape of the hole to plan for.
Setec_Fl
I actually have a similar question. Did you end up removing yours?
I have a 2007 Ar210. The factory controls are trashed. I want to remove them and put something new there. The current screw spacing is 3 and 5/8 inches. Most of these new controllers are around 2 1/2 inches. So I’m not sure what to do. Maybe make a fiberglass plate to mount under the new controller?
DRAT
Sachse, TX
never removed it. couldn't decide what to put in so i left it and moved down the list.
fnkycld
Orange County, CA
212S
I replaced mine recently. It is a 2013 212 SS with the round Clarion remote in the transom. I have to remove the plate for the clean out plugs and reach into the back of the hull. There were 2 small 7mm nuts on the back of the radio and a "C" shape bracket holding it in place.
JetboaterSC
Did you replace the remote with something else entirely? Or a newer model remote? I have the round remote and it is shot. Do you have any pictures? TIA!
sunbyrned
Louisville, KY
What year is your boat? I had to either find the same remote for my 2012 or buy an entire new system altogether because other remotes would not sync with my Aquatic AV. I put out a feeler on this site for one and someone had one they wanted to give up. If you have a newer boat or different sound system, you may not have to replace with the exact same thing.
JetboaterSC
Hey There! I have a 2012 AR210. It came with a pre-installed round Clarion remote (hard-wired) in the swim deck. That's good advice, I will look into that. It also may be as simple as a busted fuse, I haven't taken it off yet to look at it.
sunbyrned
Louisville, KY
You might be in luck. Maybe the new Clarions can work with older Clarion head units. Wasn’t the case with Aquatic though.
