replacement scupper valve
rick johnston
Marblehead, Ohio
getting ready to replace the factory original and want a good stainless replacement. Have a name, Attwood Scupper Valve and dimensions but where do you buy?
2004 SX230
any suggestions?
thank you all
Rick J.
Scottintexas
Corinth, TX (DFW)
Gym
Falmouth, MA (Cape Cod)
boudin
Lake Livingston, Texas
I bought this one:
https://www.replacementboatparts.com/stainlesssteellongscupper112hose.aspx
I used 3M 5200 to seal it in. Had trouble getting the scupper hose back on and had to expand it a little with a muffler expander tool, then it slipped right on.
When using sealant, it a job for 2 people. Someone to hold the scupper in place from the back of the boat, and then someone to tighten it from the inside with a large set of pliers.
-Greg
Gym
You might want consider using 3M 4200 or life calk. If you ever needed to remove a fitting with 5200 you'll need dynamite.
Papa
Lake Sinclair GA
I had a 05 SX230 and used the Attwood scupper. Wood definitely use 5200 to seal. Should never have to take this out again.
Papa
