Reset check engine connext
Dan Ruehl
Greeting all.
Believe me, I have searched. I did find the battery voltage mod, and that will help in the future. Here is my issue.
2016 242 LSE.
The house battery lost a cell and killed itself. Got home fine. I bought and charged two new batteries.
The engines run perfectly
I am getting a stbd check engine alarm. The alarm starts as soon as the connext system boots and before the engine is started. The engine runs perfectly, but the alarm continues to go off.
Im almost certain this is left over from the low battery sutuation
How do I reset the check engine alarm?
I’ve already disconnected the batteries, cycled the batt switches and ignition key....
TIA..
Dan
Dan Ruehl
Greeting all.
2016 242 LSE.
TIA..
Dan
Dan Ruehl
Sooo...loose battery cable behind the switch. Pita but nothing really wrong.
So problem solved?
If the error doesn't clear, trying simply starting and stopping the engine 3-5 times in a row. That has been documented to clear an error.
Dan Ruehl
So problem solved?
Yes, solved. But thanks
eHall
Had the same thing today. 2017 242X. Lake has a fair amount of debris from recent rising waters. Pissers working but starboard overheat/error. Cycling engine 3 times consecutively cleared it.
Nosliv
How did you get to the screen?
