Mainah
- Chapin, SC
- Limited S
For those who have missed it in buried in other threads @Ridesteady has added full time throttle synch to his product for Yamahas. I belive it is shipping automatically with current units. For those of us that purchased prior to 2019 @Ridesteady offers an upgrade program for $75 plus shipping where he will send you an upgrade stick to be able to update the software.
Well I did this yesterday while doing some other projects and it was super fast and easy. Not just me easy but anyone easy. The included directions were very clear and you should certainly follow them but the short version is.... remove 4 phillips screws from top cover, plug in stick, turn on power, wait for green light, turn off power, remove stick, replace cover done. The cool part is that the upgrade did not change any of the user programmed settings. I have not tested the function yet but will post on that in about a month hopefully.
My only piece of feedback for @Ridesteady and tip for anyone who has already installed is that the following settings have to be changed to use it and they were not mentioned in the instructions even though he did mention them in a thread somewhere. With his quote below.
“ENG SYNC: FULL” setting provides for engine sync anytime the boat speed is above 8 MPH. “SYNC MSTR: AUTO”, which allows Ridesteady to select which engine to adjust for synchronization, must also be set for “fulltime” engine synchronization to work. They are not default options, so they must be selected in the settings if “fulltime” engine sync is desired.
