BoomZilla
- SS
I have a 2016 212SS that I bought new and keep on a lift in SW Florida. I use the boat a lot and love it with almost 400 hours already. Even though I flush and rinse down religiously with Salt Terminator and have a Sunbrella cover, I have experienced a number of saltwater issues. I'll describe those below but would also like to hear what others have run into so I know what to watch out for.
The Latches on the ski locker and clean out port cover corroded through the first year. These are plated zinc and where the pin goes through for the hinge the zinc seems to get exposed and corrodes badly.
The rear speakers rusted out, one of them to the point that the magnet fell off when I pulled it out to replace it. The Polk speakers are not marine rated, they are for "Jeep and RV" use if you look them up on the Polk website.
While most of the stainless steel fixtures are fine, several, such as the clamp for the table stand and the hinges on the rear hatch rust up quickly. While this hasn't affected their use, they look ugly.
Finally, last week I went to start the boat after not using it for over 2 weeks and there was a terrible racket from the port jet drive. Turns out there is corrosion building up between the stainless steel sleeve and the aluminum housing around the impeller along the bottom, see pic. This makes the sleeve bulge out until it hits the impeller.
