seadek question
jikirk1
AR195
Does anyone know if you buy replacement mats for 2018 ar195 , swim platform, p/n F4B-U351H-00-00, it is the Seadek. Mine came with the Seadek swimplatform, just wanted to make sure it was the same. Thanks . I have attached pic . Please confirm this is Marine Mat.
HangOutdoors
Royal Oak, MI
Unless I am wrong, and I am sure someone will correct me. That is not SeaDek it is Marine Mat. If yours had been swapped out or changed you could probably match it. Can you post a picture of what is on there right now?
Crob83
Indianapolis, IN
AR195
@HangOutdoors is correct. I have the same boat, it is Marine Mat (Yamahas supplier) on the swim platform unless changed out by you or PO. If it says factory match it should be the same stuff (Marine mat) that came on the boat when new
