Sems vinyl paint ...Pic attached
Blazin14
Elkton MD 21921
Painted seats..I thought it came out well. Just sharing my progress
Pleased with sems products.
ToddW850
Destin, Florida
I'm not the slightest familiar with this product. Is this to paint faded seats? Or paint and change the color of the seats? Any idea how this stuff will hold up? Just curious, as I have an interest now.
BigN8
Corinth, TX
Sems is a vinyl paint. We use it to paint logos on commercial PVC roofing systems.
Bruce
Royal, AR
Your seats look great!
How does the paint feel? Did you paint all of the seats or just the grey?
Blazin14
Elkton MD 21921
@ToddW850 The seats were faded and had stains that I could not remove. I will let you know at the end of the season how well the white held up. I did paint the grey tops last year, which are directly in the sun, and they held up good
@Bruce This time I only painted the white, not the grey. (SEMs sail-white). I also used SEMS "Tac Free" clear coat as the last step which is suppose to make the seat not feel like you spray bomb'd them. I think they feel like new seats - non plastic and stiff. I know what you means as I painted seats 25 yrs ago in my VW and they felt plastic and stiff, I also used over the counter spay can.
Cray16
How many cans did it take?
4x15mph
Downingtown, PA
Came out great and it looks like there are a number of prep products, plastic paint, etc. Thank you for sharing. They have limited colors but maybe I can go with red or yellow for my interior.
VONCE
Dayton, OH
I, too, am unfamiliar with this stuff. Looks good, though! Got any "before" pictures?
Too bad they don't make paint that fixes ripped vinyl...
CrankyGypsy
Tampa, FL 33615
SeaDoo
Challenger
never used SEM, but I redid the entire interior of my Rubicon in 2012 with the DupliColor line - I did the dash, doors, console, seats, and carpet. the dash/doors/console still look like it came from the factory that way. the cloth seats are a little faded (which I knew would happen from sliding in/out of them - it doesn't show on clothing, except maybe white pants). I'm pretty anal and I think the seats still look fine, all things considered. touch-up should be easy, though. when I first did the seats they felt stiff, so I "buffed" them with an old pair of jeans to soften the dye/paint. the carpet I brushed soft with a nylon brush.
when i first considered it, i found numerous failures on the internet using this stuff, but saw some success stories. as with most failed internet projects, failure usually results from poor execution - the tool is always blamed before the inept user:
I believe the key to hard panels is using the PREP SPRAY and applying numerous, very thin coats.
a factory-look on fabric can be achieved with slow, tedious, perfect taping at the stitching and piping. i also think it helps to remove the covers and run them through the washing machine to get any body oils off. carpet needs to be scrubbed and rinsed thoroughly.
on two-tone seats, overlapping the previous, lighter color for a couple light coats (then re-taping at the intended edge) can help hide the old color at the seams and within the stitches.
you wouldn't know it, but I also used VHT last spring to change the color of the middle strip on my swim deck cushions that a previous owner replaced. i prepped the seat with a very light wipe of acetone because i didn't have the prep spray.
@Blazin14 not sure from your pics, but is the SEM Sail White a bright white or a slightly off white? it looks bright. I just bought the VHT White Satin to redo a used bow filler cushion and touch-up some other cushions, but it is like super-bright snow white and doesn't match ...though it does match the gelcoat!
Marvin willis
Morehead city nc
I did my old boat seats. Lasted years. Paint out lasted the vinyl. I don't remember brrrberry the name brand but you can buy it any auto parts store $8 per can
Cgrayson81
Colorado
AR195
Did you find anything to repair ripped or messed up vinyl????
Cgrayson81
Colorado
AR195
Any type of product for vinyl repair? I have a small spot that not quite ripped but the power washer messed it up. Brand new AR195 seat is the issue.
Scott
Sellersburg, Indiana
212S
Is there a color to match the grey portion of the seat on a 2008 AR230?
CrankyGypsy
Tampa, FL 33615
SeaDoo
Challenger
for my 2005 AR230, I used VHT SP953 (Light Gray Satin) because the previous owner replaced them with the incorrect color. Your gray may be the darker area on my old cushion, so you might want to try VHT SP954 (Charcoal Gray)? It held up great for the three more years I owned it.
Trevor Shipman
Charlotte, NC
Man, I keep thinking that’s there’s no way spray painting my seats could turn out good but the pics I’m seeing looks great!
I mean can you tell at all that they were painted or do they have a normal vinyl look to them?
CrankyGypsy
Tampa, FL 33615
SeaDoo
Challenger
I practiced on my Jeep years prior. I did my Jeep in 2012 and it is still holding up really well, even on the fabric seats ...granted, it is garaged (minimal sun) and I've only put 15k miles on it since. seeing the failures on the internet, I came to the conclusion that proper prep and several light applications yield excellent results. don't try to bang it all out in a day like the import car kids do.
it was impossible for anyone to tell that I painted my boat cushions unless I told them - and they could only tell by the very slight difference in color and shininess of the interior seats. they came out looking factory dyed. the paint does look a little more matte, but if you do adjacent cushions it won't matter.
Murf'n'surf
Naples Florida
There is Tear-Aid and Liquid Leather kits available. There are pro leather/vinyl repair guys in every town if you want it to look better than DIY
