Serious skipping
Willbvt
AR192
Plugs are gapped to spec fuel is treated. Bad coils???
ToddW850
Destin, Florida
Are you able to post a video of it?
FLBulldogger
after you treated the gas did you refill the tank with good gas?
Willbvt
AR192
Refilled the tank with fresh 93 octane fuel, not able to get video but only getting 30mph out of it
Willbvt
AR192
Is there an on board diagnostics with these Yamaha boats?
Beachbummer
Houston TX
Octane allows the fuel to hold out longer without blowing up, preventing detonation and backfire, so combustion occurs only when the spark is present.
Additional octane does not hurt, but there is no improvement unless the engine can accommodate the higher octane and adjusts timing for it.
Mixing octane will average it out (notice at the pump there are only 2 tanks but 3 fuel grades sometimes? They mix it too)
Putting high octane fuel on the boat is not the cause of your problem. Look elsewhere.
FLBulldogger
Our boats should run on 89 not 93. 93 is to rich.
The supercharged engines in the 192/195's according to the owners manual need a minimum of 91 at the pump octane number.
Willbvt
AR192
I put a bottle of the red heet as well as 1 1/4 bottles of sea foam in the fuel tank and since i bought it 3 weeks ago I've only put 93 in it. It is running much better had no issues today. I'm thinking I might have sucked up some crap from the bottom of the tank and clogged an injector.
FLBulldogger
Thats great it takes some time for the RED to work and the addition of the NEW fuel also helped great news! If the PO did not use 91 octane thats a problem also if the gas that was in the tank was a ethanol gas it will separate into two different structures so the addition of the RED and the seafoam will take care of the "water" that separtated from the gas..
KevJul2019
Harrison Twp, Michigan
2015 SX192’s only need 86. I only run 89 octane and I hit 59 miles an hour all the time.
FLBulldogger
I guess when they changed the SC for the 195's the Octane requirement changed...Good to know!
