Size of Trailer Wheels
CDENsomnia
Linwood, KS
Anyone know the size of wheels that will work on our shorelander trailers? I have some old aluminum 14x6 wheels I might be able to replace the stock wheels with. The offset looks to be right in the middle. Thoughts?
Bruce
Royal, AR
Do they have tires on them? 14" tires are not as available as 15".
If they have tires on them and the tires are of sufficient capacity to handle the boat then it would be fairly easy to install them and see how they work.
Boat Crazy
Lebanon Missouri
I have the MFI trailer, but all should be the same. Not sure what the JJ stands for, but rim is 14 x 6 JJ.
rocknracing
Winfield, MO
I just put 15x6 with 0 back spacing wheels on our 12 242 limited S on a shorelander trailer and they fit great.
piney1
Charleston SC
KXCam22
Kamloops BC
Trailer rims are different and usually have zero offset. They are actually vehicle rims from the 1980's. Some old ford ranger wheels fit but newer vehicle rims almost all have a big offset. Cam.
