Skid Wheels for Shorelandr Trailers
RobbieO
Sacramento River Delta
212SE
Anyone having a problem scraping your trailer on your driveway? I’m having that issue and looking for suggestions for adding skid wheels. Thank you
Zechbruder
Dallas, Texas
Maybe something like this that you wouldn't have to weld on:
anmut
212S
No issues - is your hitch setup level?
RobbieO
212SE
RobbieO
212SE
Yes...Thank you...I don't want to weld my trailer. I'm not actually sure it was my driveway. I haven't seen any evidence of scraping. It may have happened at the dealer. Thanks again
2kwik4u
Georgetown, IN
I've scraped mine a few times. Broken the bolt that holds that little plastic piece on the rear crossmember :(
Here's what touches first on my '17 AR190. Crossmember bolt hits JUST before the keel........This is with the tongue jacked up in the garage. I've scraped the keel a few times in one particular gas station (that I no longer visit for this very reason).
Front was WAY WAY high
RobbieO
212SE
Another option to research: BRIDJIT 3-Piece Expandable Curb Ramp Set: Amazon.com: Industrial & Scientific
That version is on the more expensive side, there are other versions out there that might be cheaper and fit what you need...
I have those on my driveway because the developer installed really steep curbs. Anyway, after further investigation, it must of happened somewhere else. Its not that bad, I just want to make sure it doesn't rust. I ordered a touch-up kit for my trailer from Shorelandr before I even took delivery. and it matches perfectly. What a PIA to order it. Shorelandr doesn't sell to the public. But I finally got it. If your trailer has scraped, I highly recommend the kit.
