CrankyGypsy
- Tampa, FL 33615
- SeaDoo
- Challenger
they have to come off because i'm doing some repairs. i'm having a heck of a time removing the large plates (not the small grates - those are both off).
i've cut away as much of the silicone out as i can along the bottom with a razor knife. on the vertical surfaces, i used guitar strings (wound and non-wound) to cut/slice down through the sealant like cheese. i've also used a syringe to inject 3M Adhesive Cleaner - though it fails to actually "inject" so i've done my best to "squirt" it between the surfaces, but it isn't penetrating deep enough like i had hoped.
anyone have any experience or better ideas at getting some separation between the gelcoat and aluminum plate mating surfaces where the 6 mounting bolts secure through it?
UPDATE: solution is here.
