Spare Drain Plugs
Scoop
NJ
242 Limited E-Series
I am used to solid metal drain plugs but my 2018 Yamaha has a rubber/plastic drain plug. I assume the plugs are reliable and not easily cross threaded when inserted but I would like to pick up a spare. My Yamaha dealer was not much help - where/how can I order buy a spare plug?
Anyone have any issues lessons learned regarding the drain plugs? Thanks.
MidnightRider
Zumbro Falls, MN
Malibu
Wake
I believe the part number is F2J-U2280-00-00. You can find in on a parts sight like Babbits or just do a google search on the part number and you will find a ton of places to buy it.
On the newer boats I think all the bulk head drains are the same, so in a pinch you could grab the plug from the ski locker for instance and use that one. I did order the above part though to throw in the glove box for a spare. The part comes with both the plug and the female thread side, for the transom drain plug though you just throw the female thread side away.
Scoop
NJ
MidnightRider
Zumbro Falls, MN
Malibu
Wake
I forgot to mention the two lessons I learned with the drain plugs.
1. Make sure there isn't any grit, dirt or shavings of any kind in the threads/hole or the O-ring will leak.
2. I keep a tube of this in the clean out tray all the time and use it on the plug O-ring every time out. (I also use it on the clean out plugs) - maybe over kill but if those O-rings are dry they tend to stick and distort as you tighten them.
