Speakers
Bueno90
Just went out on my 2018 fsh 210 and the speakers are not working. Any ideas what could it be?
Dean P
Florida
Chaparral
VRX
Does the head unit have power?
Is the volume turned up?
Which mode is it set too? (radio, BT, FM, AM Weather, etc)
Speaker wires connected to head unit?
Speakers wires connected to the speakers?
Check fuses?
Bueno90
Yes, the head unit powers on the volume is also set to 40. Where can i find the fuse for the speakers?
Dean P
Florida
Chaparral
VRX
There won't be. Fuse to the radio only.
I would make sure the speakers are hooked up and the radio is set to FM (for testing).
Did install anything?
Is there an amp with your system?
Did it ever work? When did it work last?
Bueno90
Yes the speakers are hooked up and i set to FM no luck. It worked 2 weeks ago. The radio and speaker are stock no upgrades.Where can i locate fuse for radio?
Dean P
Florida
Chaparral
VRX
Look behind the radio and locate the red wire. There should be an in-line fuse (typically it's a glass fuse in a black cylindrical cylinder). Twist in to open and inspect the fuse.
Does everything else (electrically) work okay?
BigAbe75
Litchfield, IL
different boat, and a modified stereo... but after I bought my boat, I did a fair bit of driveway boating with the stereo on.
I had a similar problem, eventually. The head unit had power, but no sound through the speakers. Finally figured out that I had run the house battery too low and it couldn’t power the amps. The stereo was powered by the start battery, so it was still functioning.
Maybe unrelated, but something to check.
