Summers420us
- 242 Limited S E-Series
Newby boater + no depth gauge + poorly marked channel + something hard = Bang... Uh Oh!
Here it is with all the loose pieces picked out and prepped for Spectrum Gel Coat Repair
Slather the stuff on... difficult to form, it's like cake icing....
Wait for it to cure
Sand away... this was more then difficult in this area as one side is flat while the other is rounded and then you have the crown.... Oh and then it also wraps from the bottom to the transom... YUCK... Not too hard though. I got it pretty close the first try.
Reapply, sand again, and buff (could use more buffing, but I do not have a power tool to do it, so that will wait for now.
Overall I am very happy with the way it turned out. The color is a perfect match. and I got the shape pretty good. Unless you looked very closely, you would not be able to tell a repair was made, and with a bit more buffing, forget it, it will look perfect.
Wait for it to cure
