Brad_Ct
- Alva Fl
- SX
It finally has gotten into the 70's here for the past few days so I pulled the boat out of hibernation and cleaned it up. Got a lot done, replaces the wheel bearings and tires on the trailer, fired up both engines on the hose for the first time since replacing a engine and rebuilding the carbs. and fuel pumps. Interesting thing happened though, I replaced the fuel filters and after doing so the air/fuel separator kept sucking air, it turned out one of the filters is leaking were the two halves are put together.
