Standard Garage Fitting Adjustments / Tire Pressure
jchandler311
Hey guys, I bought the 2019 ar190 two months ago and have issues with fitting in the standard size garage entrance. I've removed the bimini, its brackets and I have to remove the tower light and the tower still scrubs. Whats the lowest pressure I can deflate my tires to without causing any tire damage?
Michael-Nash
Make sure you've got the tower as low as it will go. Should go below the height of the windshield. 2019 models don't need the threaded extensions.
https://jetboaters.net/threads/how-to-get-your-2016-ar192-or-ar195-in-a-garage-less-than-7.10369/
Mac’nCheese
Can confirm. I bought a 2019 AR and lowered the tower to below the front windshield. Just have to get up in there and adjust the nut on the support wire.
I do also have to lower the front of the trailer as low as it will go. I have to push the boat in by hand, as the boat sits too high when the trailer tungue is connected to my truck. Ended up buying a trailer valet to help out.
ehresmann5
What size socket is needed to adjust the nut on the support wire?
