Starboard engine Not Starting when Hot
Hello, my Yamaha AR210 starboard engine starts normally when cold, runs normally. However, if I switch it off, it cannot be restarted immediately. We have to wait 10 to 15 minutes before being able to restart it. Could someone advise me on the probable cause? I’m in Mauritius and there is no Yamaha jet boat dealer. Thank you, Olivier
With both engines in neutral, run the no wake mode at level 3, approx 2100 rpm’s for 10-15 seconds, then return no wake to off before shutting down your engines. That should help with re starting when the engines have been in use.
