STBD engine not starting
Amar Nanduri
SeaDoo
Challenger
Hi Guys. I brought my boat home and started to flush the engines. I fired up the port engine and after a few minutes discovered that the water pipe was winterized and no water Is flowing through. I shut off the engine , turned on the water pipe and The port engine fired up properly and I was able to flush the engine. Now when I try to start the STBD engine nothing but pin drop silence. I can't even hear any starter kick in. I checked that the blowout plugs are in place and the hatch is sealed.
I did a complete half day of boating without any issues.
Any troubleshooting tips? Much appreciated.
Best
Amar
Amar Nanduri
SeaDoo
Challenger
The engine finally started after I left the engine hatch open for sometime to cool the port engine. I also opened and closed the blowout plug hatch.
What a relief :)
Ilmmct
Wilmington, NC 28411
Did the overheat warning indicator go off? Check the dipstick on both engines to compare.
Amar Nanduri
SeaDoo
Challenger
No indicator warning lights or sound. Nothing but silence. I will do the oil change tomorrow and see if things are okay.
Best
Amar.
Bruce
Royal, AR
The issue was most likely the cleanout port hatch switch. There is a switch for each engine. If the switch is not closed the engine will not do anything.
They are also often the cause of engines stalling after crossing a wake.
Amar Nanduri
SeaDoo
Challenger
Oil change done and spark plugs replaced. Both engines purring like babies. :winkingthumbsup"
