Rushfan67
- Raleigh, NC
- Other
- 222S
Ordered mine today!My Stoltz Roller came in today and just went out and installed it. Went with the 3.5 and seems to be perfect for the trailer.
View attachment 93217View attachment 93218
Looking for the same thing. Where did you get yours and do you have any part numbers? Looks great!My Stoltz Roller came in today and just went out and installed it. Went with the 3.5 and seems to be perfect for the trailer.
Thanks and here is the linkLooking for the same thing. Where did you get yours and do you have any part numbers? Looks great!
Thank you! I need to get one for sure.Thanks and here is the link
Boattrailerparts.com
25001-3.5 inch Stoltz Bow Roller with Bells for Yamaha Jet B
www.boattrailerparts.com
So true.. I should have done this long ago. I was keeping a cloth between the hull and the roller so it wouldn’t scratch the black hullYour hull thanks you. Should be the first upgrade to any Yamaha.
Might just be something to do with each different trailer. The 3.5 seems to fit mine perfectly. I know a lot of others have gone with the 4 and it works good too.This is always an interesting discussion the dealer said the 3 1/2 inch one that I purchased would not fit so they ended up installing a 4 inch one on my AR 195 and it fits perfectly.
How does one fix bow marks from the trailer roller??My Stoltz Roller came in today and just went out and installed it. Went with the 3.5 and seems to be perfect for the trailer.
Yes you can install on the trailer with the boat on it as that is what I did but it's easier if you do it the next time you take it the to lake.I finally pulled the trigger and bought one. Rookie question here: can you install this with the boat still on the trailer or that not possible/recommended?
