Stuck on the water thanks to PLASTIC
RIDINwithRICK
Unfortunately today is a sad day as I am stuck in the water due to plastic all up in the impeller. I was able to cut out most of it however the boat won't start as their might be an unreachable piece near the back that I won't be able to get out until I pull out the jet pump on land. Anyone have any ideas before I TOW it out of here
AZMark
Phoenix, AZ
It won’t turn over or won’t fire up?
Bruce
Royal, AR
If it will not turn over and does not have spark then either the cleanout hatch switch believes it is open, the neutral switch believes it is not in neutral, the battery is not providing power to the starter, or something has actually prevented the impeller from rotating.
The first two are more likely than the third or fourth.
MR-1 engines have fuses under a cover on the ECU. You may have similar fuses on your 1.8.
RIDINwithRICK
Called for a tow and waiting for them. Is there anything I should know when being towed. I heard that sometimes that a tow can mess up the engines. Is that true? What can I do on my part?
Bruce
Royal, AR
Do not tow at more than 5 MPH. That is covered in the owners manual if you want to show the tow operator.
Alternately you can clamp off the cooling water hose but it is good to tow slowly anyway.
RIDINwithRICK
OK, thanks for the info. Much appreciated
mrcleanr6
new jersey
275SD
by doing this do you NOT have to clamp the hoses anymore?
i wouldn't say that but without the reverse gate 1/2 closing the nozzle off you are reducing the back pressure in the pump so it doesnt back up into the engine. Lets say it might get you another couple mph of tow speed. Its just an extra safety measure. The only 100% way to block off the water is clamping the cooling hose. I keep 2 pairs of small needle nose vise grips on board to do this. If your hoses are in a tight location like mine then they are the easiest thing to clamp it off with.
RIDINwithRICK
Ok, i have an update. Boat was trailered back to the house. I pulled out the jet pump and took the rest of the hard plastic out of the impeller. Realized i need some new bushings for the steering as it was getting difficult however now i figured out that the bushings were kind of wasted. I wonder where I can order new bushings. However I got back to try to start the boat and now I'm having issues starting the engine as it wont turn over and i am receiving a communication error. Ahhhhh!!! My dealer won't be able to even check it out till next monday which is pretty good compared to other dealers. Is there anything I can do to troubleshoot and figure out until next monday when I take it to dealer. I appreciate all the advice given and will be doing more and more research to get my fsh 190 back on the water. Thank you in advance
Bruce
Royal, AR
tabbibus
Lake Lanier, GA
RIDINwithRICK
Thanks for pushing that product. Just purchased, i hope it fits my 2016 fsh 190 and my steering improves
JASmith
Minnesota
nice just ordered a set as well, glad you put me on to it! stock ones do have some nice play in them. Hopefully I ordered the right set!
Bruce
Royal, AR
@RIDINwithRICK, @JASmith, the inner and outer diameter is the same for all Yamaha boats. The only difference in the two versions is the length. The short ones might allow a flange on top and bottom. The long ones can be cut in half if you prefer.
JASmith
Minnesota
Cool, I'm not too picky, as long as it works with my cobra jets secondary steering rod, which it seems like either way it will. I'm good with whatever is easiest!
What error are you getting?
Not turning over could be the clean out tray cutout....try taping a coin to the spot where it closes as a quick test.....or have some start it while you are depressing the button manually.
