Stumped - what is this elastic netting for on my 2020 242SE???
Soonerlt
Mt Juliet TN
Turned my SX195 into a 242SE this weekend. I’m usually pretty decent at figuring things like this out, but for the life of me I can’t understand what this elastic netting is for on the new boat. It appears to be similar to what is used in SUVs to hold small items in place and it also appears to go with the hooks installed next to the port captain’s chair. I’m sure I’m missing the obvious, but I’m stumped.
Fisher4
Got my boat a few weeks ago and it stumped me as well. I came up with the assumption that it is adjustable. Not real sure I am hooking it the correct way more towards the middle of the bungee but seems to work for now. Kinda wish there was just a built in shelve there instead.
Quad
No Lake, CA
I just folded it in half on mine and it seems to do the trick. Now if only I could find my glovebox key...
ZGhost
Minneapolis, MN
You’re not the only one. Still haven’t figured out mine either. Nothing in the manual I can find!
Following this thread.
Soonerlt
Mt Juliet TN
@Quad I tried the folding in half method too, but couldn’t quite get it on the hooks (this appears to be the only logical way IMO). I guess I should have probed further when the dealer said it really wasn’t very effective.....
I’ll give it another shot tomorrow.
As for the glove box keys, mine were taped to the back of the glove box with masking tape.
Quad
No Lake, CA
Oh! THAT “X” OF TAPE! I saw it yesterday and noted I needed to pull it off to see what was there. Despite the New England chill today, I may paddle to the mooring to investigate; thanks!!!
props2you
Round Lake, IL.
You're correct, it actually is for the port side area by the glovebox with the hooks. The bungee net is larger to accommodate soft coolers, garbage cans, etc.
ShesCrafty
Webster Groves, Missouri
Agreed... except it’s not really a bungee net, as it should be. It’s grossly oversized/odd sized. That is the problem with it.
Soonerlt
Mt Juliet TN
@Quad Would love a pic of your installed net if you happen to go fetch the glove box keys!
tabbibus
Lake Lanier, GA
Not usually something that I take pictures of. But here is the only image I have where I captured it.
Fold it. Hook it. Put a can in there. Without the can it doesn't stay taught
Soonerlt
Mt Juliet TN
Helpful! Thanks @tabbibus.
Quad
No Lake, CA
Will do! Didn't get out there today because it was so dang cold. Hopefully tomorrow.
BigAbe75
Litchfield, IL
I installed on the 4 corners as intended, then used black zip ties to hold them in place. It sags (a lot) when not in use. But, I like how it expands plenty for the beach bag etc and holds fine when in use.
Soonerlt
Mt Juliet TN
"Sags" is an understatement. - seems like it is more effective as a tripping hazard than anything else. The zip ties are a great idea though (and discreet).... I can't help but think some marketing guy at Yamaha came up with the idea late in the development phase and all they could source was a 3-foot long netting from an auto supplier.......
Quad
No Lake, CA
Not the greatest pictures as lighting was suboptimal, but this should show the idea. The right side has the “ends” of the net and the left side has the “middle”.
Soonerlt
Mt Juliet TN
Thanks @Quad
Really appreciate the pic and hope the trip out yielded two glove box keys!
Quad
No Lake, CA
@SoonerIt - it did! Thanks for the hint!
Soonerlt
Mt Juliet TN
Thanks @Julian
I found your mod last night while searching the threads. This is validates exactly what I intend to try out. Assuming the carpeted block is to keep the trash can stable and upright while underway?
The block is needed to keep the top of the garbage can from being pressed against the side of the boat. Otherwise the netting pulls the can against the wall and prevents the lid from opening and closing properly.
