Sub Installed
Augieol65
Downers Grove
Finally got around to getting this Polk audio 10” sub installed. The sound improvement pre and post sub is amazing! Think I’m all set now. Stock 6 speakers on 1 amp, wetsounds soundbar on one amp and now this sub on the third amp. Going to see how my current house battery holds up before I consider replacement or adding another. Anyone adding addition batteries to a boat that had the recessed tray? I don’t think much bigger than the group 24 fits in them but maybe?
95005
Seadeals
Greenville, South Carolina
Very cool. I can’t help with the battery size; but I would definitely look at a second with that setup. Until then, a jump pack is an easier and lighter way to insure yourself from listening just a minute too long.
Augieol65
Downers Grove
Yeah I definitely want to get one of those! More so Incase I ever need to help a buddy. Should never have to jump ours with the isolated/dedicated engine battery.
Dean P
Florida
Chaparral
VRX
Do yourself a favor and install a second battery and battery switch. You won't be sorry...
Augieol65
Downers Grove
Yeah boat already has a second battery. Didn’t know if I needed a second house battery (third total) already have two batteries wires through a DVSR.
props2you
Round Lake, IL.
You'll want to add the 3rd overall/2nd house. Search on here about adding batteries and you'll quickly realize and understand the need for that 2nd house battery. I have a DC GRP 24 starting battery and 2 GRP 31 Duracell Marine AGM's in parallel. I'm running 800 watt amp and prior to my 2nd house I was only getting 4-6 hours of run time, at best on my house GRP 24. That is no longer an issue. Do yourself a favor and add the 2nd, you won't regret it.
Start here:
Dean P
Florida
Chaparral
VRX
I only have AGM deep cycle batteries. These have plenty of cranking power to turn/start these engines. Not a problem.
Augieol65
Downers Grove
Start here:
Thanks!
