Surf foil rack/mount recommendation??
GRcrawler
Just picked up a new Surf Foil and trying to figure out a way to store it safely in a rack on the boat. This is going to be the biggest down side of a foil board. I'm hoping I don't have put it together every time we go out. Does any one have pictures or rack recommendation for boating with the foil assembled?
giroux68
Cumming, Georgia
Found this, but no photo of it with a board in it. Pricey to say the least. Break out another thousand....
brddog
Shouldn't a normal rack wide enough to handle a surf board do the trick? You may have to adjust the angle to where the board is more parallel to the tower so the fins stick straight out or straight out and slightly down from the tower.
Dylan01
Malibu
Wake
The slingshot boards are essentially a regular surfboard with a foil on the bottom. Most surf racks should work. The only inboards rack above is for the airchair, which is slightly thicker and a smaller foil (higher speed). I would be cautious assuming that rack would work.
brddog
Here is a picture of the combo wakesurf/wakeboard rack from Amarine Store.
96441
GRcrawler
Thanks brddog, that's the exact mount I was looking at because of adjustability. I was a little worried about the fingers being a little short
Nauti-Nurse
Lake Lanier Georgia
I have the same board and a similar surf width rack. Works for mine but be cautious with that particular setup, the bungie cords will indent/damage the soft top slingshot board. LOL I used two folded up paper plates between the bungie and board once I realized it was damaging the board. It was what I had on hand that day. Now I use two cut pieces of cut pool noodle lol.
AZMark
Phoenix, AZ
Has this worked out well for all of you long term? Any damage to the soft boards?
I’ve got to get a rack on my boat this season, I’m currently disassembling every time and it’s super annoying.
GRcrawler
If you have a light weight high-end board I would not recommend a normal surf rack. There is too much swing weight and it will start to flex the board/glass. I haven't found an answer yet.
AZMark
Phoenix, AZ
Bummer, thanks. I have the slingshot wf-2, it seems fragile which is why I haven’t done anything yet.
