Did you water test it?Thanks for the feedback. I checked the hoses and everything appears to be installled correctly. I do have great water pressure from the house water hose. Still nothing from either pisser. This is supposedly a new take off svho intercooler. I never had an issue with the sho intercooler.
The problem I have is I don’t have any water flow....not even a trickle coming out of the pissers. Figured I had a clogged line but I don’t see one. There is however water coming out of the rear of the boat. Any thoughts on a possible cause?My house water pressure is 72 PSI and water flows fine from both of the pisser outlets from the SVHO intercooler. I have the factory water supply line going to the intercooler and 2 dedicated lines leaving the intercooler. I added a 2nd pisser for the extra outlet. I previously tested my performance of both intercooler discharge lines going to a Y connector before I added the 2nd pisser. If the water temp was above 82 degrees and I was running the boat hard (above 6500 RPM), heat soak would reappear after about an hour of continuous running. After adding the 2nd pisser, I could not get heat soak to return at all. Moral of the story, if you run in warm(er) water and do a lot of watersports, by all means, run the 2nd dedicated line from the intercooler to a 2nd pisser.
Because I have not seen the heat soak return in any form once I added the 2nd pisser, I decided to not run a dedicated water supply line to the intercooler but YMMV. For an apples to apples comparison, I run with 4 of us in the boat (my wife, myself, and 2 middle school kids), full fuel of 30 gallons, and a 25 quart cooler stored in the port side helm locker. Also of note, I am 6'5" and 280 pounds so my weight is probably more than most. With that said, I can run WOT all day at 7200-7600 RPM and 42-45 MPH on the speedo with no heat soak.
Barring any kinked lines, obstructions in the intercooler itself, I don't see any other causes. I would haul the boat to the lake and check the pissers once you start the engine. If there is no water flow once you start up the engine then you are probably clogged somewhere. If you have flow at the pissers while in the lake then it just means you have low water pressure from the hose at your house.The problem I have is I don’t have any water flow....not even a trickle coming out of the pissers. Figured I had a clogged line but I don’t see one. There is however water coming out of the rear of the boat. Any thoughts on a possible cause?
Of the three pissers you have, is water coming out of the pisser closest to the stern?The problem I have is I don’t have any water flow....not even a trickle coming out of the pissers. Figured I had a clogged line but I don’t see one. There is however water coming out of the rear of the boat. Any thoughts on a possible cause?
If you did a dedicated line off the jet pump strainer cover directly to the SVHO intercooler, you will NOT get any flow from the factory flushing line as you have removed it entirely from the original cooling system. The dedicated line requires pressure created by the impeller to flow water. The factory flush kit is connected directly to the 4-way T upstream of the jet pump strainer. Since the flushing kit is typically used on the trailer, the turning impeller can't force any water through the strainer. That means no flow to the intercooler. This no big deal, intercooling is not required by the engine for flushing. To flush the intercooler, you can install a flushing adapter T with in-line isolation valves in the intercooler inlet line to flush it directly, or simply backflush by feeding water through the pisser.So what was the fix? I have the exact same problem. Swapped out my Intercooler today (SVHO) and I now have Nothing out of either pisser and I have plenty of water pressure. I did add an additional dedicated line for the new SVHO inter cooler. I was going to try a Y connection but it really shouldn’t matter. I should have something coming out of the pisssers. Appreciate any help!
Looks like a smoking gun to me. Nice find!
