How is the platform foam holding up?I ended up making my own with a double sided EVA foam sheet I got on Amazon.
It’s holding up nicely. I think it will need to be replaced in a couple years but so far so good. There is a light layer that can come off if you scrub it with a stiff brush. My dogs nails scratched a few spots when she was trying to climb up once. She’s 75 lbs so it’s expected.How is the platform foam holding up?
I am looking for some form of foam or mat to put in storage areas to be able to store/transport a metal auger post for when needed at some shallow anchor spots on our main lake...
TY!!!
Do you happen to have a link to either the foam or loop mat still?It’s holding up nicely. I think it will need to be replaced in a couple years but so far so good. There is a light layer that can come off if you scrub it with a stiff brush. My dogs nails scratched a few spots when she was trying to climb up once. She’s 75 lbs so it’s expected.
I used some vinyl loop mat for some of my storage compartments. It’s heavier than the EVA foam and breaths better but don’t stick down like the foam does. It’s more money than the foam foot for foot but might fit your needs, as well.
Here is a link to the vinyl loop. It’s not the same company I got mine from but it looks identical.Do you happen to have a link to either the foam or loop mat still?
TY!!!
TY Sir!!!Here is a link to the vinyl loop. It’s not the same company I got mine from but it looks identical.
https://www.amazon.com/VinLoop-Vinyl-Mat-MattingExperts-Comfortable/dp/B01D1VJCG2
The foam is from Blacktip. They have their own website but you can get on eBay and I think even Amazon.
https://www.amazon.com/BlackTip-Jetsports-traction-Sea-Doo-Footwell/dp/B00843WACQ
The adhesive on the foam from Blacktip works really well.
