SX195 swim platform speakers
Johnboat
Texas
SX195
Hey y'all,
I want to add speakers to the swim platform area of my SX195. I have several ideas. I welcome any advice and thoughts.
1st idea. Behind the swim platform seats. I have seen some people add speakers here, but always wondered if that sounded any good. Kinda like putting a pillow in front of a speaker.
2nd idea. Drill two holes in the swim deck "see photo". I would probably need to add a 1" King Starboard speaker ring to get the depth needed. I've heard many comments about water splashing up on the swim platform and causing concern. I don't seem to have that issue, I have never had water splash up this high. I don't wake board or surf. And I only boat freshwater lakes.
3rd idea. Buy tower mounted speaker pods and alter them to mount to the bimini.
4th idea. Build custom fiberglass speaker pods. I would permanently mount them to the boat and gel coat them to look seamlessly integrated. This would be the most labor intensive option and the most original. I haven't seen anyone do this. But man what a pain in the ass.
adrianp89
Tampa Bay, FL
252SE
2 is great for freshwater. I did it in salt and the speakers started to rust.
adrianp89
Tampa Bay, FL
252SE
Also 5 would be trim the back cushions and do it similar to the premium trims.
Crob83
Indianapolis, IN
AR195
The 3rd picture definitely would not work, there is no way water doesn't rush up there. You don't have water on top of your clean out ports at all after a day of boating?
adrianp89
Tampa Bay, FL
252SE
3rd works, I’ve done it.
as far as 5, one or two people have done it here. Have to get upholstery shop to take care of it.
212s
1000 Islands
212S
You're right, that would sound poor and a waste of time.
That would sound good, but I wouldn't recommend it as speakers are moving cones and I could see them getting damaged from large waves hitting them - water is heavy and a wave hitting the cones would not be good. I've had large wakes roll right up to the edge of the upper swim platform, and my boat has stock speakers mounted at the sides of the seat backrests and they typically don't get wet up there. But the lower platform gets hit hard and often.
Bimini poles are not super sturdy - I wouldn't do this.
That would look great, but a lot of work as you said.
How about combining 3&4? Buy speaker pods and mount them to the fiberglass above and to the side of the rear seatbacks, perhaps just aft of the bimini mounts?
Johnboat
Texas
SX195
I never get water
Good idea. I found a flat surface mount for speaker pods that usually mount to a tower.
Johnboat
Texas
SX195
I don't seem to have that issue. No water over the top of the clean out ports ever. I have water halfway up the tube but on coming out. I have not had water over the lower swim deck, even in a rapid slow down. I've been hit with wakes and just roll over them. I've had four large adults in the back and still no issues. Im more worried about someone kicking them with a foot than water damage.
Crob83
Indianapolis, IN
AR195
I do not see how that is possible, but that is just my opinion. Not that you don't have water on your clean out ports, but that water doesn't rush up there where the speakers would be. Water rushes over my lower swim deck everytime I slow down at a somewhat rapid pace
212s
1000 Islands
212S
The newer hulls have drainage channels to the sides of the hatch so water just runs back out. The 250/252 models have the same drainage which is better than the drain tube under the swim platform.
I think you just haven't noticed it yet - I always have water wash over the lower platform when slowing down, and whenever a wake comes from the rear. It's normal since the lower platform is only a few inches above the water line.
Johnboat
Texas
SX195
Bouncing more ideas around. I found these silicone speaker covers on Amazon. I wonder if I put the speakers on the lower swim platform with a on/off rocker switch and covered them with the silicon covers. This way when were hanging out with the boat anchored, we could pull off the covers and turn on the rear speakers. When the boat is in motion the speakers would be off and covered. What do yall think?
212s
1000 Islands
212S
I think the water pressure from wakes and waves might pull them off and you would lose them. The Fusion unit on my rear swim platform is on the same level and comes with a silicone cover. But I don't think it's secure enough to leave on while using the boat - I use the cover for winter storage only. Also, if the point of the covers is to protect the cones from pressure damage, the silicone covers are soft and would still transfer some of the compression pressure from wakes and waves to the cone. It might protect, but it also might not.
I think the pods mounted aft of the bimini is still your best bet.
SamN44
Marietta, GA
I have a SX190 and when I was considering this, a powered sound bar seemed like it might be able to be mounted on the bimini top more easily than a regular speaker pod.
Johnboat
Texas
SX195
Sooo... You guys were right. Water comes over the swim deck. I just didn't notice it before. I let my wife drive while I sat in the back and told her to go from 25 MPH to neutral and sure enough, water came rushing over the lower swim deck. Im either going to mount small 4" speaker pods or a sound bar to the bimini.
212s
1000 Islands
212S
What, you didn't believe us?
Sound bar sounds like a good idea.
