Tail Light Replacement?
jared24
Columbus, GA
I have a 2013 AR190 w/galvanized trailer that I need to replace the right tail light on. The clear housing that fits up into the red lens that holds the bulbs broke, causing the bulbs to bounce around and bust.
Does anyone know if the below Wesbar tail light would be a direct replacement as far as mounting (No drilling)?
Also, when it comes to splicing wires for this install, when using waterproof heat shrink connector butts, do you have to use a special crimper, or will pliers and a heat torch do the job?
Thanks in advance for any help!
https://www.amazon.com/Wesbar-40307...ng=UTF8&psc=1&refRID=DS78F3SCNDZSC2MVZSB0#Ask
Mounts on 2" studs, which is basically every trailer made. Regular crimper will do fine.
