Tango - FINALLY RUNNING! NEED SOME MINOR PARTS...
Anchorsaweigh
Sugar Sand
Tango Xtreme
Changed almost the entire ignition system and it runs like a champ. So, I am in the process of doing all the cosmetic stuff. I am in need of the following:
- Part number or the length of the lift cylinders for the engine cover
- New gas cap (the closure snap is missing from mine
- Bow light (I know there are plenty of replacement lights, I'm looking to match the existing bolt holes)
- Where to mount the bilge pump
By the way, this is a 1999 Tango, not a Tango Extreme.
Cheers
Bob
Chuck Buck
Lake St Clair
Sugar Sand
Mirage
Not to be a smartypants, but I have two questions Bob:
1) Did you have it running before?
2) Are you the mechanic throwing parts at it?
Anchorsaweigh
Sugar Sand
Tango Xtreme
1) It died on the previous owner
2) I took it to a mechanic and they're throwing parts at it (testing them first)
3) I am a LONG TIME boater and should have known better than to buy a non-runner
Chuck Buck
Lake St Clair
Sugar Sand
Mirage
...should have known better than to buy a non-runner
C'mon, where the fun in THAT?!
Seriously, if it was you doing the diagnosis, I'd suggest a slow, careful read of the factory service manual, something not everyone on the clock has time for, then I'd go back to square #1 and check all the basics - all wiring connections clean, bright and tight, all fuses/breakers tested, and make sure all related wires had good continuity and no internal breaks or high resistance. As for your mechanic? They should have done everything I wrote already.
From my experience, at least your failure is constant and not intermittent. Intermittent failures can sometimes make a technician want to suck-start a shotgun (just kidding).
Blkrvrbart
Sugar Sand
Tango
Glad it’s running!
My bow light was bad, this is the near identical replacement
Attwood Bi-Color Combination, Deck Mount Navigation Light https://www.amazon.com/dp/B001O0DIOU/ref=cm_sw_r_cp_api_glt_fabc_81JRQ22JCBWN6G9T71HM?_encoding=UTF8&psc=1
My bilge pump is mounted with epoxy between the fuel tank and the engine
take a measurement from pin to pin hood up at the height where you want the hood to open to and go to your local parts store to get the closest you can find for the hood supports.
Can’t help you on the fuel cap. But I’ll be watching for the answer.
Chuck Buck
Lake St Clair
Sugar Sand
Mirage
Not so fast on the supports there Bart! o_O There's a lot more to consider than just extended length. E.g. compressed length, force, type of ends, etc.
I would check out SUSPA. They make supports for many different OEM's (my Speed Queen front load washer has SUSPA supports as does my pickup cap).
Stomp10
Sugar Sand
Tango
Have been away from the board for a while so, not sure where you're at on this.
I bought mine on amazon.
Search for:
Perko 1319DPGBLK Vented Fuel Fills
It's an exact replacement
LanceH
Sugar Sand
Tango
Cheers
Bob
I'm trying to find the part# for the gas cap as well for my 1999 4+2 Tango...as well as an engine compartment key latch. Where can I can these 2 items?
Thanks for any help or direction anyone can provide.
Lance
