Geoff Cooper
- Thailand
Ok i have got some more Photos for you, I added a lot of Photos to my previous post on the subject but ran out of space so here are the rest of the Photos that show what damage has occurred while in use, they follow on from the previous post, It also shows the construction and i try to show as much detail as possible, When these boats are damaged they are taken away from the Marina so Tourists don't see what has happened and they are left to be repaired or just rot away after they have been stripped of anything useful, Any questions i will try to answer, I hope you find it interesting.
This has had a bad smash it's took the side out of it.
Inside construction just wood covered in a thin layer of plywood
You can see the Epoxy filler that is just spread over the Plywood and sanded flat
You can see the side all smashed in
Damage to plywood and the filler has all fallen off
More Photos of the side damage
These are small fabrication shops around the Marina, They repair the Trailers and the Tractors
More small Fabrication shops around the Marina
This is the Marina it's about a square mile in size and there are maybe a thousand of these wooden Boats here
More views of the Marina, I will add more to this post as and when i think there is something interesting to show you i hope you enjoy.
